Hay mamaA
There is a way to make your shovel not rust ,but there is a little work involved every time you use it you need to clean it with water and a rag to dry it or a hand wire brush to get all the dirt of then dry it with a rag ,have another rag with oil on it and give it a coat of oil each time you use it it will say nice and shinny and it,s easy er to use when its cleaned up the dirt doesn't stick when you use it next time. You don,t need a heavy coat of oil on your shovel try it and see what you think and if you have a rag with oil on it ready every time it doesn't take long to to it each time you use it.
