JD Z225 with JD 18.5 hp.
tries to start, acts like it is Hydro locked, replaced starter four times because one showed a 400 amp draw.
replace it again with a used one this time.
it won’t even crank, when I try to start it, and acts like the battery is dead, and barely moves the engine. Battery is brand new, and I even try to start it with the new battery (fully charged) and a jumper box attached.
I remove the spark plug to which it cranks fine, I removed it to blow out any excess fuel it might have in it, I did not see any fuel come out. I did this while I had the fuel line blocked off. Reinstall the spark plug, and it again doesn’t want to crank, or spin over the engine.
Ran a four gauge wire directly from the starter to the battery, so it is not an electrical problem. Checked negative to ground on the battery and added another ground.
