Skag won't start
Ron&Pam
We have a Skag FreedomZ 725cc 26.0 hp Briggs and Stratton. Will start with starter fluid for a few seconds, have gas flowing at the carburetor, but i don't think it's going into the carburetor. Is there any kind of switch that would possibly keep gas from flowing into the carburetor? TIA ( It ran fine last time we mowed, which was right before all the flooding here on Lake Texoma).
shiftsuper175607
Does that engine have a fuel cut-off solenoid on the bottom of the carburetor bowl?
Turn key and see if you heard it click...may be better with two people.
Or run a wire from the battery plus terminal + and touch the spade terminal on the solenoid and see if it clicks.
Is the gas line shut off?
Could there be water in the carb?
Ron&Pam
sorry..gas is turned on.....and i guess it's possible there could be water in the carb
