LeakyBriggs
(I also posted this in the Briggs and Stratton Engine section then thought maybe it should be here. Sorry to moderators. Feel free to delete or adjust as necessary. Thanks.)
Hello lawn and engine folks. Having an issue now with my lawn tractor starting
Details:
Older Simplicity Regency (20 years? Not sure. Time and memory gets away...)
Briggs & Stratton 22HP Intel V-Twin
Valve cover stamp:
Model 44K777
Type 0115 E1
Code 071015YG.
Issue I'm having is a no start situation. Meaning the engine does not turn over when turning the key to on.
Things I've confirmed:
Battery is good.
Foot pedal switch is not blocked and presses in normally.
When turning the switch to "On", the fuel cutoff solenoid clicks.
But that's it. Not sure where to start for troubleshooting. You know, test here first, if good, move to here, test, if good, move to here.
Thanks for any input & help.
LeakyBriggs.
Details:
Valve cover stamp:
Model 44K777
Type 0115 E1
Code 071015YG.
Battery is good.
LeakyBriggs.
