I have a Simplicity javelin 20 hp kohler (which I just short blocked) with a 38" deck. I have an issue with the drive belt riding up the tensioner pulley and falling off and just rubbing until the belt breaks. I have gone through 3 belts now, and even took the pulley and pto off to check it out. Are there supposed to be spacers or some sort of thrust washers in between the bottom of the block where the crank comes out and the pulley to help line up the tensioner and the pulley or do I have a bad tensioner? I am done going through belts and wondered if anyone knew a fix to this? I got the mower for free because of a cracked block and fixed it, and now I want to use it(or sell it) since it only has 90 hours on the whole thing. Any advice would be greatly appreciated.
