Simplicity hydrogear bypass
Japgolf
I have a simplicity regent that will not unlock the transmission rear wheels into the neutral position for manual movement. The hydrogear transmission
model number is T2-cche-4x3b-15x1. The unlock release bar moves ok and swivels the bracket against the stop but will not disengage the gears. If
anybody has had this issue I would appreciate any advice the service manual that I downloaded did not address any bypass repairs. Thanks, JP
mechanic mark
Post 7 digit model # from Simplicity tractor.
Read Troubleshooting in Operators Manual above. Jack up rear of tractor & see if you can rotate wheels, report back thanks Mark
Make sure the external brake calipier is fully releasing. The engagement do corrode and stick holding the brakes on.
Japgolf
Did once I will recheck a second time
