I have a Simplicity 7117 hydrostatic garden tractor that I am having trouble starting. When I go to start it and turn the key nothing happens. I can then jump start it and it starts just fine. I then mow my yard and put it back in the garage and turn it off, I try to re-start it right away and nothing happens. I have replaced the battery and it does not help.
Seeing you replaced the battery and I take it that its a fully charged battery, but it only starts OK with jumper cables. The only thing it can be is a bad connection between the battery cables and the battery. I just don't see what else it could be. Unless the new battery is junk.
#5
reynoldston
I have seen this type of job come into my shop. Someone will buy a new battery and not clean the dirty positive battery cable end. Now they wonder why the mower wouldn't start. Just a little sand paper works wonders.
Last year I put a new battery in it and it started every week I wanted to mow, until it got dry out and did not mow for about 3 weeks, then I was right back to having to jump it to start it and it was dead again after I put it back in my garage. Any more ideas would be great, and thanks for the replies I have gotten so far!!
#7
BlazNT
Hook a trickle charger to the battery when not using.
