deerman206
- Jul 17, 2014
- 1
- 2
I have recently acquired a Simplicity 20 GTH with a 60" deck from a family member who owned it since new. It lost hydraulics over a year ago and was parked. I have gotten it running and confirmed that there is no drive, steering, or deck lift. This tractor has over 1500 hours but has been well maintained. Initial observations, I have noticed quite a bit of play on the pump end of the driveshaft yoke. I don't know if that could have caused excess vibration that damaged the pump? Any recommendations on where to start with this issue? If I end up needing to proceed with pump repair/replacement, are there other wear items that I should replace while I am doing this work?(engine mounts, lines. etc.) Thanks in advance.
