White Oak Dave
- Mar 13, 2022
- 10
Hello, I recently posted a problem with a Command Kohler CV23S in a John Deere L130. Oil soaked plugs. The advice I got here was awesome and the engine now seems to be fine. I have one last issue, after I mow for a few minutes and put the engine under a load, I shut the tractor off and a couple seconds after it is off I get a backfire from the muffler.
I have read some suggestion to let it idle for 20-30 seconds and that seems to eliminate the backfire sometimes and I have shut the engine off at high RPMs and that has worked every time I tried it. I also changed the solenoid and that did nothing.
Any suggestion?
Any suggestion?
