03 Cub GT1554 is shredding drive belts after a few hours of use. Pulleys etc. are in good shape and spacers etc. have been replaced. I notice that the replacement belt is super tight after I install it. My thinking is the belt is so tight that it generates heat and destroys the belt. Belt is very hot to the touch after a few minutes of use. I have other mowers and they have loose drive belts but work fine...I did not replace with an original cub belt. Is there an adustment to loosen tension on the drive belt that I am not seeing?
