Short?
BlackMike
L 160, My hour display stays on all the time. I think it might be draining the battery. I can jump it to start. Any ideas? Thanks
Most hour meter are internally battery powered.
Also please verify model number.
JD Parts results>
Sorry. It is an E160. The display has wires connected to it. It used to go off when the key is off. I have an X340 that does the same.. thank you
I don't have a wiring diagram on that model but it sounds like you may have an ignition switch problem.
Thank you so much. I think it might be the switch as well. Tried blowing it out with air hose. Even tossed a little WD in it. Guess I will start there.
