Shaft seal
Shawngporter
I need a shaft seal for wheel motor on lt2400 silver eagle. Does anyone have the number off the seal so I can match it instead of buying the $160 kit?
Shawngporter
I know what the seal kit is I just need the outer shaft seal out of the kit.
Google seal kit PN 500444004 which is for the Dixie Chopper 200049, 200050 White RE530 T series wheel motors. Amazon has it for $100 with free delivery option.
And the kit includes a bearing.
Also would recommend ordering the Front housing bearing PN 530018000 as the above kit only contains the Rear housing bearing.
