Series 5 Wheel Weight Kit
SPVFD47
Does anyone know where I can find one? New or used ? I've searched for the Snapper part numbers. 6-0517 and 7060517 with no luck of finding any available. I hoping someone else makes something that is compatible and someone here knows. I'm also looking for snow chains too but I may be able to use something universal. Any help is appreciated. Thanks.
They are just standard wheel weights that you buy by the size of your wheels. E bay is a good start to look for them. It seems like most lawn tractor dealers should be able to order them for you also. You might have to drill some mounting holes in your wheels to install them. I just used car tire chains on mine in which I had to cut down in size.
