Here's a little background on this thing first
I have a '08 Troy Bilt Bronco lawn tractor with a Kohler 18hp. Me being new to home ownership and maintaining outdoor equipment, I abused this thing pretty bad. It got its first oil change about a year after we bought it. I change the oil, but couldn't get the filter off. I finally got the filter off the next year I think. Anyhow, she was smoking pretty bad on start up (white smoke) and it seemed to be the valve cover leaking and the oil would gunk up right at the bottom of the cover, which is right above the exhaust.
I replaced the cover and gasket and I guess I didn't tighten it up enough. It apparently was leaking again and we didn't check the oil after the first few times of running it with the new gasket. I ran it, it ran but was lacking horsepower. I parked it and the wife hopped on the next day while I was at work and she noticed the same so she parked it. Thanks to ridiculously high temps (for Virginia) and lots of rain, I couldn't do anything with it. Went to start it about a week and a half later and it just clicked.
I should mention this thing sat outside several times, in the rain and all. The flywheel (gear? sprocket?) is rusted as well.
Starter is fine as far as I can tell, but I cannot budge the flywheel on the top of the engine, even with the plug removed. I tried some oil and also tried some PB Blaster in the hole and let it sit, but still nothing. I have a feeling it's seized up and will need to have internal components fixed.
People have mentioned it may have bent a rod?
I bought a new ZTR because we needed the grass mowed badly and I am not paying someone once a week to cut our 2 acres. I do want to fix this one though, if possible. It would be good to have two mowers anyhow IMO and it gives me MUCH needed experience in engine work for our other machines (ZTR, tiller, push mower, generator, string trimmer). For someone who is a mechanical newbie, but CAN learn with the right help (books, mainly), is it even worth me putzing around with? I don't have a garage, so the engine would have to sit in a shed.
Needless to say, this was a nice slap in the face. From now on, my stuff gets taken care of properly!
