... was much better than the first (badly bent blade).
I took my Cub Cadet 1046VT mowing last weekend. No problems, except for operator error.
This is the first time I've had a bagger on a riding mower. I've learned that wet isn't good. It tends to clog the chute. I also found out that without the bagger, I can mow grass that is nearly as tall as the hood of the tractor pretty successfully. I probably went too fast as I had to go over it again to get the cut level.
I likes it.
Matthew
I likes it.
Matthew
