Grassbagger
Need some help troubleshooting this problem. Mower runs fine until I go up a slight grade (maybe only 10 deg) then sputters and if I don't quickly change the grade, it will die. Usually starts right up again. Going down a grade or level ground, no problem. Sometimes when I make a sudden lunge forward from reverse, it will cut out just for a second. This all is with a high RPM, blade engaged, gas tank full, and a new clean fuel filter. The Numbers: Craftsman 917280350. B&S 17.5 HP engine 31C707 0603 B1. Any help appreciated.
