Issue with my Briggs 18.5 Intek on a Sears DYT 4000 lawn tractor. Replaced blade belt and fired up to test. Stopped to check the belt. Belt fine but I noticed oil dripping. Turns out it's from what looks like a small breather on the fuel pump. Over the next 10 minutes I figure out there's significant blow by to the crankcase. With the filler lid off it almost looks like the exhaust. Over the life of the tractor I replaced the head gasket twice. I can think of nasty things but the crazy thing is the engines starts and runs smooth. Scary thing is I checked the oil during this and is was very low. Didn't change after last season but believe I checked it in spring. In the past with the gaskets it was somewhat obvious with the way it ran. Though it may be a little off under load. Didn't want to push it. What's the most likely culprit?
