kennethrbest
- May 19, 2024
- 2
- 3
Is there a maintenance schedule for the transmission? I've had the same mower for over 20 years and if there's fluid in the transmission, I'm thinking it could be due for a fresh refill. Also, exactly how would I drain and refill the fluid(s).
Also, has anyone discovered a way to replace the transmission pulley without dropping the trans.
