toggenburg
- Jul 25, 2012
- 2
- 5
Hello, new member here.
A 2002 Scotts L2048, owned 4 years.
In the last few weeks, had situation where one of the PTO leads was torn off right at the PTO connector.
Recrimped the ground wire, reinserted and ran fine for a week.
Then PTO stopped working again. This time it was the double black lead torn off the same PTO connector. Repaired and was fine for some days again.
Has happened 2 more times, so the very next time, I spliced in about 2.5" of braided wire and soldered into the pin. Then, yesterday, the same double black broke off, and I spliced in similar wire and soldered. Because the wire length looked like it would catch on a metal notch on the top of PTO (I did not want a twisting of PTO to catch the extra wire length and do more damage), I used a loose loop of ty-wrap through the right frame side, to get the wiring up out of the way.
It ran about 40 feet then PTO cut out.
Now, here is what is weird. Sitting on mower in neutral, engine on full revs, if I engage PTO, nothing happens....still have PTO pulled up, and try forward, no PTO movement. BUT, if I instead try reverse with PTO engaged, without pressing the reverse interlock switch, still no PTO, BUT when I momentarily, release that reverse/override button, the PTO engages, but then engine kills.
Neither I nor my JD dealer has a wiring diagram. I talked to JD, and they felt it must be the PTO switch is going bad.....I got low ohm readings on all the correct positions (com to NC with PTO sw mashed in, and com to NO with PTO sw pulled up), so seemed OK....JD convinced me it was PTO sw, sold me one for $26 with a no-return policy....bought it, installed it, and still no difference. Could it be wiring trouble or just the sign that the PTO itself is bad?
