scored two more
I use a 69 on the main jet and 79 on the idle jet this seems to work okay you can go 67/77 but you will use more fuel.It does not take much to improve the surging issue be paitent with the idle jet it takes a little more time to drill out than the main jet also dont get confused when drilling the idle jet as it is the oposite drilling procedure of the main jet meaning dont drill on the screw slot side Oh yeah just picked up another 10323 for 40.00 that already had the jets drilled.runs good but looks like it was ran hard and put away wet
