tlebel
- Nov 12, 2020
- 1
- 4
I have a 2016 XT1 Enduro Series LT 46 in. 22 HP V-Twin Kohler Hydrostatic Gas Front-Engine Riding Mower. I've had problems for a while where it doesn't engage teh starter, just clicks when hitting the key, but if I turn it back and to start a few times, it goes eventually. But todays problem actually scared me a little.
Was doing leaf pickup and had just dumped, when I ran out of gas. Not too worried, I rolled it down the hill towards the shed (and gas can).. figured I'd see if I could start it and get a little more out of it, then..... a click and starter spins, but doesn't engage the flywheel, just spinning, I turn the key back and it kept spinning! I pull the key and release the brake pedal; it keeps spinning! I get off the seat and it keeps spinning! At this point I run and get wrenches to disconnect the battery, as it's drawing a lot of current. By the time I get the negative cable off, the battery is HOT.
This seems like a huge safety issue if the starter will still turn on when both safety switches are open. Once cooled, touching the cable to the post engages the starter, with key off, seat and brake safety switches open.
So my hunch is that the solenoid is somehow stuck on, but wanted to ask the gurus in this forum for their opinion. (been reading here, but this is first time I've posted).
Thanks.
Thanks.
