- May 6, 2010
- 11,983
First make sure you have a known good spark plug. then unplug the kill wire going to the module, and crank the engine. If no spark then replace the module. If you have spark, then the problem is someplace within the wiring harness, like short, bare wire rubbing frame, bad safety switch, etc.
