Scag and other mower manufacturers must go along with what the pump and wheel motor manufacturers recommend for use in their products. Newer and higher end hydrostatic drives have been changed to full synthetic oil, but here again, the manufacturer of the drive unit has specified the type of oil to be used in their products and not the mower manufacturer. Compliance with the manufacturers specifications is necessary to maintain warranty requirements while the machine and or components are still on warranty, when the warranty has expired, then the operator is on their own. However maintaining specs is highly recommended.
