Model: STT61v-35BVAC
Serial: K2200647
Problem: Nothing happens when i turn the key..I dont hear a "click" and the starter does nothing.
Back story-Ive been having to use a battery box to jump start the mower every time i needed to start it...thinking i just needed a new battery...well i finally bought a new battery and installed it and got the same results...frustrated i hooked up the battery box and started the mower to get it on the trailer...got it home and tried to start it and nothing happened and here i am a few days later after testing and buying this and that...im at a point i dont know what else to do or try...
I can get the starter and motor to crank ,but not start, by jumping the wires at the starter relay.
I have checked all safety switches & PTO, bought a new relay,(2) fuses,battery, spark plugs & ignition switch, cleaned all electrical connections including battery and grounds and still get nothing when i turn the key...
anything else i need to check or try before i go buy a wiring harness and/or module?
Serial: K2200647
