Peninsula Acreage Mowing
- Apr 1, 2017
- 1
I have a Turf Tiger and it fails to start via the key, after you shut it down for a short time.
When I turn the key, it makes a clicking sound like a flat battery solenoid, battery reads 12.7 volts
I have fitted a secondary start switch, from the positive battery terminal to the starter solenoid, so I can move it.
The 12 volt 40 amp solenoid mounted inside the control box also clicks consecutive when trying to start.
I look forwarded to your thoughts!
Regards
Graeme
Regards
Graeme
