I have a Tiger Cub that I can not get to crank. Don't know if it will run yet cause I can't get it to crank. I have jumped out every interlock and installed a new relay and module , I have tested the starter switch and it seems ok. I can jump the black and green wire on the relay to ground and the starter will engage.Discovered that using a test lite from gnd to the relay coil. I understand that the module sets up the ground to energize the coil. How can I test the module? What is inside that thing? Can you get around it?
Did engage engine long enough that it will start (fire) but when you release the switch it stops!
