Mad Mackie
 - Jul 11, 2011
 - 50
 - 1,851
View attachment 23480View attachment 23481View attachment 23482
Here are some pictures, I hope they got uploaded, that show the outer bearing seal has come loose. Grass has contaminated the bearings. This seems to be a poor design on the part of the manufacturer, I wouldn't think the bearing seal could come loose so easily.
A good hydraulic repair shop should be able to determine what caused the seal to move. Both where the seal sits in the housing and where the lip rides on the motor shaft will need to be cleaned up. The hydraulic shop will do this.
The green residue in the motor housing is locking compound. The hydraulic system and this wheelmotor may have overheated which can cause the locking compound to soften allowing the seal to move under system pressure, just a thought.
Design wise, this is normal for this type of hydraulic motor.
Mad Mackie in CT
