SCAG Tiger Cub Spindle Assembly
tony75
Have a SCAG Tiger Cub
Model# STC48A-19KA
Serial#: 9257108
I need to replace the spindle of the spindle assembly. There is a 1 9/16" / 39mm nut on the bottom of the assembly. There is not enough clearance between the spindle housing wall and the nut itself to fit a standard socket in there to remove the nut.
Is there a thin walled socket someone could recommend or some trick anyone knows of in order to remove this nut?
My SCAG dealer says they never take apart the assemblies to replace a shaft, they just replace the entire assembly.
Any help would be appreciated.
Time to make your own. I use a grinder and a drill with the socket attached to the drill. I run the drill and grind down the socket till it fits in the whole I need it to. I normally buy cheap tools for this.
I do have the complete assembly off...I need to get the nut off at the bottom of the assembly.
You might can hold it in a vise and take a cold chisel and a hammer and tap it an back it off that way. I can't remember but it might be left handed also.
