SCAG TCII Won’t start after refueling
Gunhead58
I own a 2018 SCAG Tiger Cat II with Kawasaki engine. I ran out of fuel and filled the tank bank up. It will not start. Both tanks were empty and I’ve filled both. Any suggestions or recommendations appreciated. Thx.
7394
Since ya ran it MT, might have air trapped at the carb.
I'd be removing that gas line & see if it flows w/key on..
Gunhead58
I took the line off right where the gas filter is. Turned it on and NO gas is coming through.
7394
Now ya gotta dig deeper. Check it before the gas filter. If you get gas flow, clogged filter imo.
Tiger Small Engine
Change fuel filter and blow back through fuel line with an air compressor into tank and make sure it is clear.
