Scagnewbie
- Sep 24, 2022
- 2
I have a Scag walk behind (somwhere in the '10-'18 range, belt driven) that my father inlaw gave me. It came with the ride-behind attachment.
I've been using it without issue for the last few months, and today when I started using the machine the balance between the deck and the motor already seemed a little loose. over time it became nearly impossible to use because anytime you'd hit a dip the motor would fall back and the deck would jut up so badly that one of the flywheels would make contact with the frame and spark.
Any ideas as to where to start? could it be the spring has worn out? very new to walk behind machines so I am really at a loss right now.
Thanks!
Thanks!
