R Rludington Member Jul 16, 2018 #1 Can you bypass having to set the brake before starting ? I have an employee that is having a hard time with the brake. (Weak left leg)
BlazNT Lawn Pro Jul 21, 2018 #2 The brake is to protect your equipment from being damaged while starting. Anything can be bypassed if you're smart enough but pretty much won't find that answer here.
B bertsmobile1 Lawn Royalty Jul 21, 2018 #3 HE can use a stick. Got a one legged customer who uses his crutch to set a LH brake and he is 92
