kawamoto26
I'll put the original carb back on tomorrow.
Hoping you meant 0.006" and not 6mm. Please confirm.Just for grins and giggles, I checked the valve clearances and fine tuned them to 6 mil. Still won't run.
By electronic module you mean SAM unit (spark advance module), there is no testing these. Look up the symptoms online of a faulty SAM unit. I replaced mine on my Scag this year after 20 years of use. Bought a used one on EBay for $75 versus $575 new. Be sure you want it because typically no returns on electrical parts.Yes, sorry 6 mil (0.006"). After checking everything and going through the whole electrical system I'm left with just the electronic module. Anyone know how to test this? Wonder if the bad voltage regulator damaged the electronic module, which apparently may play a part in the fuel mixture. I'm much better with mechanical problems. Electrical issues are not my strength.
