Hi Bert and group,
Lets look at this from a practical view:
Dealer cost of repower engines.
Time and equipment involved just to clean the machine before engine removal.
Time involved to prepare the machine for engine removal and removing the engine.
Time for engine cleaning, teardown, inspection and repair cost estimate or repair.
Time to inspect other areas on the machine that need to be addressed as this machine has 1,650 hours on it.
Fuel hoses, hydraulic hoses, V belts, pulleys, spindles, tensioners, and in the case of a Turf Tiger, the drive shaft for the deck, this list goes on as you know.
And then actually doing the work!
The job isn't "done" until all the paperwork is completed, the shop area is clean and ready for the next job, the junk parts, waste oil and trash have been disposed of, the job is paid for and the machine is delivered back to the customer in full functioning order, this list goes on!
Having worked in several shops over the years, this sort of work in season takes a lot of time when quick turnaround of service is important. Encouraging the customer to consider a new machine benefits both the customer and the shop as this sort of work is off season when quick turnaround isn't as demanding.
Just my thoughts! :dance1:
