7394
- Sep 5, 2014
- 90
- 5,157
The 36" LZ still has the HG 2800 wheel motors. I should think that would be a plus on the lighter 36"er..Thank you for letting me know! I know many of the zero turn mowers say 10 or 15 degrees max. It still surprises me as I used to mow with an old Dixon zero turn (maybe 15 years ago) on a hill that was around 50 degrees (near the side of the road). It worked well unless it was too wet and then the rear end would slide down the side of the hill. You had to be careful or else (when really wet) the rear tires would slide sideways and scrape the grass with it. It was incredibly fun but the yard looked terribly afterwards!
I'm curious how it does towing. Most of the folks I spoke with think the 36" will do fine with the smaller stuff (dethatcher or aerator) but not so great with a roller or maybe sprayer.
