Scag Liberty Z 48" vs 52" - torn
jetech
The Scag manual says 20 hours and the Kawasaki manual says 8 hour? Confusing but I'm going to go with the 8 hours.
Thanks
I just bought a Liberty Z 48 with the Kawasaki. The Scag manual seems a bit flaky. In the maintenance chart it calls for oil change only at 8 and 50 hrs, then oil and filter at 100 hrs. In the INITIAL RUN-IN PROCEDURES of the manual it calls for oil and filter at 20 hrs. Seems like they need to review the manual. I have filters and oil on hand so I plan to change both around 8 hrs. This is a fantastic mower.
7394
The 8 hour oil change is important. The engine comes to you with 'break-in' oil in it. Do NOT wanna leave that in there longer than the 8 hour period. Or the oil filter that is full of that oil as well.
After that I change mine at end of each mow season, or @ 50 hours. Always with new oil filter too.
Remember you have (two) HG 2800 pumps on your Liberty that drive the rear wheels, & they require a change of both oil filters & the 20w-50 oil Scag recommends @ 50 hours. After that I believe next service for the pumps is 400 hours.
Enjoy your new machine. That is the same size Z I'm thinking about getting as well.
jetech
After that I change mine at end of each mow season, or 50 hours. Always with new oil filter too.
Remember you have (two) HG 2800 pumps on your Liberty that drive the rear wheels, & they require a change of both oil filters & the 20w-50 oil Scag recommends 50 hours. After that I believe next service for the pumps is 400 hours.
I got the oil changed this weekend a bit early but this was recommended by my Scag dealer, so it has new oil and filter. Where are you seeing that the ZT-2800 hydros require oil and filter at 50 hrs? The maintenance chart in the manual shows 100 hrs and then every 400 hrs?
BTW avoid using the ampersand in posts as it prevented me from replying or previewing my post. The system thinks this is a link and being a new user it would not allow me to reply.
BlazNT
2 more post and all will be good.
jetech
Nope, has nothing to do with the amount of posts. Has to do with the post I was replying to having ampersands in the body of the post.
Darryl G
Once you are past 5 posts it won't matter.
BlazNT
After 5 post the @ means nothing.
7394
I read it on a one of the sites, possibly Hydro-Gear site. And a fellow / friend owner said same thing.
7394
Re: Scag Liberty Z 48" vs 52" - torn ( Hydros service @ 100 hours )
Correction, Scag Liberty states @ first 100 hours for hydros service.
I apologize for the bad info.
butwhenido
Thanks, this is exactly what I am going to do. I'm just getting around to the 50 hour mark and I did change it and filter at the 8 hr mark.
Great machine, should had bought one a long time ago.
