Scagman01a
Scag hourmeter P/N 484565 will clock time when power is applied to it.
Scag hourmeter P/N 483537 will clock time when the applied power passes 13.1 VDC as the charging system voltage increases during engine operation.
Both have a non replaceable internal battery to keep the screen live and will indicate engine service intervals of 25 hours being due. This service reminder will come and go as the hourmeter clocks time. You do nothing to the meter except read it. It is clocking time when the hourglass symbol is flashing.
You can buy either of these meters at Scag dealers or on line.
These meters are sealed and waterproof. Hobbs hourmeters as pictured in a previous thread generally are not sealed.
Thanks for the input.
