I’m adapting a Scag 48” Tiger Cat II to an older grass collector that supposedly came off a 48” Tiger Cub (year unknown).
The bottom lip of the blower intake is 1” inch lower than the bottom of the deck.
I’m concerned that it could get damaged if I use it like this. I can fabricate a bracket to raise it if necessary. Should it be at the same height as the bottom of the deck?
My deck is 4” in height, are all Scag decks the same height?
Thanks in advance!
Thanks in advance!
