Farmer Mike
Last fall this mower would (sometimes) start after repeatedly turning the key to the start position. You can always hear the fuel pump run and the volt gauge would always go to the far left at -8. I replaced the ignition switch with a brand new one thinking this was the problem. No, that was not the problem. Place key in switch and volt meter needle is straight up and down. Turn key to on position fuel pump runs and then turn to start and volt meter instantly goes to far left again no cranking, starter don't even click. No amount of times turning the key will start it now. Seems like there is a dead short somewhere. This mower is out of warranty now but it only has 116 hours on it. First day when I got it the volt gauge was defective and my dealer replaced it. Took it home and was back to dealer again within first week because of a bad oil leak on top of engine. I love the mower and it does a great job but it needs to be more dependable. Does anyone have an ideal on what I need to get her going again ?
Battery is fully charged. I've checked all battery and cable connections to frame and starter. Found one fuse and it looks to be good. All of the safety switches are in the proper positions for starting. Mower has never been rained on or wet. I'm at a loss.
Thank You, Farmer Mike
