- Feb 19, 2020
- 120
- 12,832
I wish I had one on the equipment yard to personally look at but it has been a few since last Z254 been in the shop.1] The orange with 12v should drop to zero with the arms out. I tested that out and it does as you said.
When I pull plug out of safety switch my jump across the two orange wires will start engine and even engage clutch and allow blades to run. I turn off clutch as don't want feet to go under deck, just a quick test to see what would run. What seems strange is I pull my jumper off between to orange and engine dies. That seems strange as me pulling my jumper off, is no different than pulling handle back in as that opens circuits( 2 orange wires) and the 2 blues and 1 black were opened when it started as plug was pulled out of safety switch while doing this test and they are all opened anyway when arms pulled in, have tested that with Ohms meter. Now the right arm was out maybe that had something to do with it. Still haven't found any relay.
But of course it dies if either lap is outboard as the relay de-energizes and the contacts switch the blue wire over to the kill circuit white wire. Apparently they hide that relay very well.
I think it is under the keyswitch panel.
