Mower deck Sabre blade engage.
bigmiketx
I picked this rider up from a fella and he told me that blades where not engageing on first look i noticed that the largest spring on deck pulley area was broken on one end problem is i kave no idea where it goes and cant find anything on the net that gives me good diagram on layout for this model it is 1997 year made v twin 18 hp .I also noticed a flat bar that was also hanging losse idk if that work together .Any info for a shade tree at best mechanic .Thanm you in advance.
Under the seat is a tag if you can post the details off the tag it would be gratefully apprecated.
As for your photos, upside down and with light glare they are not much use.
I have not stood on my head since I was 20 and that was a very long time ago.
Photos taken with phones oft do this could you load them into your computer first & correct them before reposting?
An image of an unfamiiar deck with strong light causing glare flares is little to no help.
bigmiketx
I will retake the pictures and i dont think tag is still on there but i will take picture of any thing i see that will give more info and thank you very much for letting me know about the pictures.
