Ferd Turgeson
- Sep 15, 2021
- 1
- 13
My parents bought a Cub Cadet RZT SX w/ the 46" fabricated deck several years ago. We all like to mow with it and find the steering wheel zero turn to be just right thing for mowing their sloped and angled yard. The only issue we had corrected under warranty was a loose stator wire that kept the battery from charging and shutting down mid stream when mowing. We do all of our own equipment maintenance between our place and theirs and have had no problems with a quick 2 qt oil / filter change and a few grease fittings. It's been a good mower and my mother even feels comfortable on it. I read through the manual and did not find too much information on hydraulic wheel motor maintenance which got my curiosity going. I knew when my parents bought it that it was a lower end unit - but comfortable for them and sufficient to do the job they needed. Besides they were tickled with it and no one had any right telling either of them that they bought a cheap mower lol. Changing engine oil and filter, cleaning / replacing air cleaners, greasing and cleaning are all about maintenance but what could I do to change at least the hydraulic fluid out every 200 hours or so? When we were shopping for a PRO level Cub Cadet the dealer(who sold my parents their RZT) brushed me off when I asked about changing the hydro fluid on the Hydro-Gear units without an external filter. I was told - no can't change any fluid without tearing them completely apart - basically a lifetime fluid unit - which of course I didn't believe for care for that kind of advice. I got the information off the pumps - they are a Hydro-Gear ZC-DMBB-CAGB-24PX unit. I called Hydro-Gear direct and they confirmed what I thought all along that the fluid on these lower end pumps are completed by sucking the old fluid out via a pump and pumping the new 20w50 synthetic oil back in (approximately 56 oz in each pump). There is an access hole in the RZT frame above the top of each pump where you can remove the 1/4" hex bolt to drain / refill each pump. On these particular units - there are no magnetic plugs or filters to content with. Just suck out the old fluid and pump in the new. The other method is remove them completely, tip them upside down, drain completely, refill and then re-install. The later is probably the preferred method and would get more old fluid out - but even changing half the fluid out is still better than no change at all. So the pump method is our plan. I would have liked to have attached the service manual for the ZT series Hydro-Gear pumps that I received today from Hydro-Gear but the file size is too large.
