This is really a question to determine if this is normal or if I should look to service my Cub Cadet RZT LX zero turn. When going forward, everything seems to be good. I have good speed and, for the most part, I'm heading pretty straight. When going in reverse, I can't just pull back on both arms or I'll basically go in a circle. It's very obvious that one side of the tractor is going much faster than the other when in reverse and I have to ease up one side to keep is straight. It will also go pretty slow, not that I expect to get the same speed in reverse as going forward. It's been like this since I bought it (2018), but I've decided to question if it's normal. A friend who has a similar cub cadet (older model) doesn't share the same experience, so wanted to see if anyone could confirm if they have the same going on before I approach the dealer on it.
