I think I'll try and replace the interlock switches...only $7.90 each. If that works it will be a cheap fix!!
check the lap bar switches you have one going bad. It is set to turn off pto when both lap bars are pulled in reverse. it should not stop pto if only one lap bar is pulled as in turning.
