rzt 22
sparky48049
Hi I am really confused I have been trying to get my rzt 22 to crank I can not get it to do anything any help would be great I have mechinacal skills just cant figured out why it will not crank
shiftsuper175607
What do you mean by "crank"?
and "can not get it to do anything"?
sparky48049
i mean i get nothing will not do anything when turning key so i tired to jump the solenoid just arch but will not turn over motor . battery is fully charged check seat switch thats fine any help
shiftsuper175607
Take out the spark plugs and see if the engine will turn over.
shiftsuper175607
yes the engine will turn over by hand it is not seized up
Will it turn over with the starter with the plugs out?
___________________________________________
Then it is a battery, solenoid or starter problem.
Most likely battery. Even if it shows voltage, check all battery and starter connections for tightness.
have you tried to jump start it with another battery?
Red jumper on lawn mower battery red post and black jumper on the frame.
