ryobi weed eater hard to start
torey69
I have a ryobi weed eater that all of a sudden last year it is very hard to start. it went from pulling 10 times to start to pulling 100 times to start. I'm whooped before I start weed whacking. I put a new muffler on it and a new spark plug but no improvement. Any ides for this 2 cycle engine?
***I moved your thread to the Small Engine & Mower Repair Forum so you can hopefully get more help with your problem.
Good luck! :smile:
exotion
When you put a new muffler on it did you clean the carbon out? Also clean carb, heat sinks, and anything else that is dirty. Starting problems for me are usually spark plug or coil
RobertBrown
Check the fuel lines and primer bulb for cracks. Look in the tank an see the fuel line is intact. There should be a filter on the end of it, this should be replaced periodically.
After trying everything suggestion, and if it doesn't improve, check the compression. If below 90 its toast.
