Ryobi cs26 string trimmer
Truckdriver09
did you test the spark plug in line or remove it to test as sparkplugs can show working but fail under load when in the unit
I tested the spark on the unit with an inline spark tester and then i grounded the spark plug to the motor and checked to see if i was getting a visible blue spark...which i did
