Read on some other forums about guys running double blades on their mowers to create better lift which led to a better cut quality. Are any of you running double blade setups on your Hustlers? I'm curious and considering giving it a try. Wouldn't be out that much $$$ on adding another set of blades onto the mower to try it out. Any input?
