Repairs RT Rear wheel drive shaft will does not engage
scpolee
I'm trying to determine what if any parts I need to order to repair my mower.
The rt spur gear spins freely when the transmission is engaged while the engine is running. When I engage the transmission when it isn't running I get the same results.
When I removed the wheel the dowel pin fell out. I've tried to remove the screw which holds the spur gear on with no luck.
Any guidance is appreciated.
I have a 2009 Troy Bilt XD rear wheel drive walk behind.
If that is the short metal pin, it should be behind the spur gear, to engage the shaft, That bolt that holds the small gear to the shaft has thread locker on it, and is really hard to break loose, Need to find something to prevent the shaft from turning to break it loose.
