two stroke and jdgreen. two excellent thoughts. i'm going to try these things out this weekend when the snow melts off the ramp of the shed. especially that start mech. also, i can rule out the drive wheel being engaged because i have to adjust the lower clutch cable spring from last year when i noticed slack in the line and the lever on top of the handle was to easy to fold down thus not enough propelling. that handle bar release got me thinking. that might not be disengaging all the way. i'm also going to test it w/o the spark plug in there. very good ideas. i'll get back to you. anyhoot, when it starts it runs very smooth. to give a better idea of how hard the pull is, if i forget to clear the shute on top of the deck when i empty the bag, i pull it half way and it stops, then i have to push down on the handle bars and back it up and notice a big clump of grass. then give it a pull and it starts. w/o any obstruction, it's about 1/2 of the clump of grass being wedge underneath to pull it. so there's something wrong somewhere.
