Poppyb1957
I have a Bush Hog ES2052 zero turn with command pro 7000 Kohler. Rocker arm loosened and push rod came loose. Put it back together and it keeps coming loose, even with lock tight on the threads. This time, I couldn't even get it to tighten down on the push rod enough to keep it in place. Help!
